Casio FX570MS Scientific Calculator Logo
A
Anonymous Posted on Apr 24, 2014
Key function for fx570ms - Casio FX570MS Scientific Calculator
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on May 22, 2018
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4761499
Points
21601
Look at the face plate of the calculator. You should be able to recognize the functions.
Use Casio fx570ms to calculate growth rate between two periods
Usually, population changes are not linear, but since you give only two points (2000, 206 000) and (2010, 240 000) that is all you can calculate. The average growth rate is given by the rise over run.
Growth Rate=(240 000-206 000)/(2010-2000)=34 000/10
If i press 0.5*0.9524=476.2m and i want it to give me the result of 0.4762
You have turned the Engineering display mode ON. In that mode, the power of 10 that are displayed are multiples of 3. In your case the m stands for milli or (1 thousandth).
To exit the engineering ON mode, press the Mode button, several times (4) until you see EngON, EngOff. Press the corresponding digit key to turn off the Engineering display mode.
Feet to meter
One foot is exactly 0.3048 meters.
How to turn off calculator
Welcome to Fixya. If you want to turn off the Casio FX570MS just press Shift and Off Button. You can also refer to the manual below for more infor about the device.
Casio FX570MS Manual
Thanks for using Fixya.
1helpful
When calculating anything to the power of zero I get an answer of -1 when the correct answer is 1.
Well, if that anything happens to be a negative number and you key in something like -3^0 without enclosing the argument -3 in parentheses then the answer given by the calculator is perfectly correct. I am just guessing what might have happened. Besides, as you well know, any number different from zero that is raised to the power 0 should yield a value of 1. Is there any point to be proven by calculating it?.
2helpful
How can i calculate inverse of 3*3 matrix using casio fx-570MS
The casio FX-570MS does not handle matrices. So you cannot create matrices, let alone invert them. Sorry.
15helpful
Conversion of log base 10 to log base 2
To calculate the log base 2 of a value, calculate its log and then divide by the log of 2. You can use either the log or the ln keys, but be consistent. For example, to calculate the log base 2 of 16, you can calculate either log(16)/log(2) or ln(16)/ln(2).
1helpful
How to convert square meter to square feet ?
There are 0.3048 meters in a foot, so to convert square meters to square feet divide by 0.3048-squared.
Top Casio Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
